(1) 2 3 »
Help
Quite a regular
From South Africa
I need some tips to make my stock A-14 kick some butt without doing the turbo or N O S thing just reworking cams stuff like that.
Posted on: 2003/1/16 20:57
Old Datsuns never die they just go faster
Re: Help
From Melbourne, Australia
take away any load or restrictions
i.e.,
- put 2 inch exhaust with extractors
- weber carb if ya can get em there, we get em off 2ltr ford cortina and escorts
- thermo maybe
- change cam too
the usual stuff really, best cheap mods is prob exhaust and carb
Posted on: 2003/1/17 7:37
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Help
From Pakistan
- thermo maybe
what do u mean by thermo? what is that?
r extractors same as exhaust manifolds/headers?
Posted on: 2003/1/17 11:39
STRONG IS STRONGEST ALONE. PERIOD
Re: Help
yeah sorry, headers and an electic fan (thermostat sensor)
Posted on: 2003/1/17 11:51
1200 Coupe Rallycar
Re: Help
From Pakistan
technically speaking, how does a elect. fan increases HP or a mechanical fan decreases HP? if we install an Elect what do u suggest we do with the mechanical?
barpk
Posted on: 2003/1/17 12:03
Re: Help
get rid of the mech if your radiators upto the job without a mech fan
the mech fan puts load on the motor that doesnt need to be there, a thermo fan will help acceleration mainly as there is less force holding the motor back
only problem is a mech fan flows a lot more air than a thermo and without a decent radiator you might overheat
same as elec water/fuel/oil pumps but the others are a lot more expensive
Posted on: 2003/1/17 12:07
1200 Coupe Rallycar
Re: Help
Quite a regular
From Pretoria - South Africa
Actualy the fan is not adding or taking away any HP, it only causes an HP restriction, try revviing your datto to 6000 rpm with a fixed fan and then without...
Posted on: 2003/1/17 12:09
Re: Help
did i ever say it was?
what time is it in SA at the moment? just out of intrest
Posted on: 2003/1/17 12:10
1200 Coupe Rallycar
Re: Help
Quite a regular
It is now 1:20 PM, for small sprints like the 1/4 mile you can even shorten the fan belt to not drive the alternator, there's pro' and cons to that one....
Posted on: 2003/1/17 12:16
Re: Help
hell you may as well drain the oil and water too, forget the water pump, rig a bottle of petrol up above the carb to feed petrol so you dont need that etc. etc.
she'll be right mate they'll let you run it
Posted on: 2003/1/17 12:21
1200 Coupe Rallycar
(1) 2 3 »
