« 1 (2)
Re: A15 Block but A12 head i think
From Freo
looks like around port, the oval ports must have been an improvement, I put another replacement round port head on a mild A12 and it was a massive increase in HP, I have just put the same head on an A14 I built for a friend about 10yrs ago, it's pretty strong, well on paper, big cam, balance more comp, I just didn't want to use the oval port(well ported) and the twins that came with the package, so I'm running witht e round ports and a Single DHLA40..
Posted on: 2006/10/2 13:38
From The garage, NZ
When i got my a15 it was exactly like urs. Had the a12 head. so it is possible to fit.
Easy replaced though.
Posted on: 2006/10/2 20:43
From Adelaide
nah.. ill just see sum other guy and buy his..
then if i blow the buttom up.. ill go get the block out of this car hahahha
so if anyway needs a a15 block PM ME.. i no where there is one.. no sezuized
Posted on: 2006/10/3 1:35
From Geelong, Vic
didnt vanettes come with round port A15s
they were like 69hp and the others were 80 something hp (or was that A14s)
should have checked if the eninge number matched the one on the cars build plate, as it could be a replacement engine sourced from a vanette
something to think about
Posted on: 2006/10/3 5:05
From Adelaide
yeh the badge on the car said it was an A14 S....
soo mmmm wat do u think
Posted on: 2006/10/3 6:01
The studs on the head are for an A12 tho, so it must have a A12 head whacked on the A15 block.
Not sure why you would do this, to give higher compression? to de-tune the engine? Maybe the A15 head was used on another application so they put the A12 head on
Do you know what the casting numbers are on the head?
Have a look in the tech section for A12 casting numbers, it should reference them all.
Cheers
Dave
Posted on: 2006/10/3 7:17
i could see some benefit of the higher compression if te valves were bigger and the ports keeping the chamber small and closed but would be better off wit an a14 or a15 oval port, fill the chamber and then grind it out for higher compression.
or just skim the head a it.
Posted on: 2006/10/3 11:06
« 1 (2)
