Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
120y brake calipers hitting mags or problems fitting
evilbetty
Posted on: 2006/10/6 12:07
well it was just brought to my attention that the 120y brake calipers can cause a few dramas when fitting 15 inch mags,
is there anyone who would like to give us some advice on how to deal with this problem?????? i heard you can cut a part off the caliper plate ,but honestly not sure if i really want to do that as i want it to be legal and safe, so are there any other options????????????????????????????? spacer plates????????????????????? custom mags??????????????????????? what mags have been used on the 120y struts with 120y calipers and how did you get them to fit ,any help and pictures would be aprecated cheers guys evil betty
#2
Re: 120y brake calipers hitting mags or problems fitting
Freak
Posted on: 2006/10/6 12:13
Wheres it rub? Inner face? I can only assume the wrong offset because 15s would definately clear the calipar height wise. They only had 12s standard. Ivee never had trouble with any normalish mag wheels.
#3
rb20
Posted on: 2006/10/6 12:15
wat rims have you got i have used 15" and 13" rims with my 120y calipers wyh out a drama
#4
john_13961
Posted on: 2006/10/6 12:20
is only a dramn on some rims that have a large DIA centre with no releif on them
unfortunatle that wot i got lol
#5
evilbetty
Posted on: 2006/10/6 12:23
well i dont actualy have the wheels i want for the ute yet so im not 100 percent that i will have the problem,but it was just brought to my a ttention by john_13961
as he has the 120y calipers and saying that his 15 inch mags are having big problems with the 120y capiers with new brake pads, i just wanted to investigate this issue for future reference as i dont really want to change my brake set up just yet
#6
evilbetty
Posted on: 2006/10/6 12:24
ohh i see bugger,well im hoping that i dont run into the same drama as you there john!!!
so what you gona do change wheels ???or calipers
#7
john_13961
Posted on: 2006/10/6 12:55
change nothing just mod lol its a very easy task and quite save it doesnt require much to be removed at all and if u cut into the support plates top n bottom of the main one all it require is a little stich weld tooooo easy i will take some pics tommorrow for ya
#8
DatsunDrifter1
Posted on: 2006/10/6 14:46
Spacers could probably help clear the calipers being that the rim will be out more but then you have to buy longer wheel studs so that the lug nuts tighten properly.
