« 1 (2) 3 4 »
Re: my turbo l20b project
From Geelong, Vic
nah one axel needs to be a few inches shorter than the other, centre is offset like all other diffs (well almost all)
im using a ute diff behind my car, no dramas as of yet but ive only driven the car 4 times with the L series
will give damage reports in the coming weeks
Posted on: 2006/10/9 12:32
From adelaide
does this mean that there is a short and long axle in the stock vp diff? Or just the r31
Still no news on my car will have to ring up tommorrow, want it for the cruise badly!
Pigdog is yours locked or open wheeler?
Posted on: 2006/10/10 8:31
1200 restoration project moving slower than it actually is
From Geelong, Vic
yes there is a long and short axel in a commo diff, dont know if they are the same length as the skyline though
my diff is an open 4.1:1 at the moment, but i have a 3.7 ready to be welded, just gotta find the time
Posted on: 2006/10/10 14:07
From Brisbane
yepp like PIGDOG said the diff centre is offset, so you need a long and short axle
Posted on: 2006/10/11 12:57
From adelaide
well i rang today to check progress of 1200, the wiring and ignition is finished, dissy modifications will be done tommorrow so hopefully tuning can begin friday and ill get the car mid next week as they want to keep it for a while to get the cold starts right.
Im not fussed as long as i get it for the 22nd!
Posted on: 2006/10/11 13:30
From Adelaide, Australia
Where you getting it all done mate? I know datsport have done a L-series lately.
Posted on: 2006/10/11 13:38
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From adelaide
At blackwood dyno tune, i hate paying other people to work on it, sooo expensive but there a haltech dealer so should get a good tune i hope!
Didnt no datsport were into that sort of thing, thought they sr20s into 1600s
Posted on: 2006/10/12 8:36
Yeah im the same, i try and do as much as possible my self. Will you have it back and running before the cruise on the 22nd, cant wait to see another L-series 1200!
Theres another bloke on here in adelaide with a green L18 1200. maybe its him thats been to datsport, i dunno i just phoned barry when i was doing my conversion to pick his brains and he mentioned he'd just done a L-series into a 1200.
Posted on: 2006/10/12 9:36
IPRA Build
From adelaide
yea i think i should unless there are some unknown problems, hope not, really want to go. Hoping to get it by tuesday/wednesday!
Posted on: 2006/10/13 13:22
Re: my turbo l20b project (update 17/10)
From adelaide
Got the datto back today, it managed 100rwkw on 8psi with the injectors maxing out at 4500rpm so i need to sort out bigger injectors before the boost goes up! Currently they are 7mgte supra ones which i thought would be plenty big enough. Since it maxed out they didnt bother doing full tune so its a bit rough and not much timing in it yet.
Also my brand new vl turbo pump is close to max which ithought is strange? I heard they were good for 150rwkw ish, anyone no?
Also have to fix a leaking injector oring, replace tps as its broken( big flat spot down low).
Clutch is worry but im hoping replacing the master cyl will fix as pressure biulds behind it and dosnt release clutch fully, but luckily i bought a spare and spare slave cyl!
Also need to re-root map sensor line as apperently has a kink
But on a bright note exhaust is nice and not too loud and the tempgauge wont push past 80degrees celcius!
It goes quiet well for low boost, get usable boost from 2000rpm (5psi) and builds from 1500rpm! pulls hard from 3000rpm but unfortunatelly cant rev over 4000rpm for safety of engine. Im glad i wil be able to make the adelaide cruise!
Also my front end bottems out over potholes etc. Not sure why i have stanza stuts, new munroe gts and king springs cut to drop top of tyre about 10mm from the gaurd! it never used to do it before? maybe i need to raise it up or something?
So once its all sorted ill need another 4-5 hrs full dyno tune and cold start remap etc!
Any ideas welcome from you guys, ill try to post more picts tonite
And is $60 each for 2nd hand 13b injectors a fair price 550cc?
Posted on: 2006/10/18 11:29
« 1 (2) 3 4 »
