« 1 2 (3) 4 »
Re: Rad support panel - effect body stiffness?
From Adelaide, Australia
Thats what im thinking, i reckon next year i'll do hillclimbs and some s/sprints and then get into it more seriously 2009. Geez the years roll on, i stopped racing karts in 2001 and need to get back on the track and have a pedal.
Posted on: 2006/10/11 13:05
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Sydney , NSW
Hey Whitey,
no problems with yours - removing original gearbox mounts is okay. Adjustable bottom arms would re-classify you as a sports sedan however.
Cheers
Posted on: 2006/10/11 22:30
From Brisbane, Australia
I cut the top of my Radiator support. 2 1mm cuts, sooo 2mm gap.
I have to spread the front of the car to put the piece back in.
I have run a piece of 25mm angle across the top to stop it "caving in".
Posted on: 2006/10/12 2:16
From SE Melbourne
Yikes Cable_Tie....
Think you may have oonvinced me!
Posted on: 2006/10/12 7:41
Mildman, Datsunless
From Jimboomba s/e QLD
ive cut mine out and bolted it back in using fish plates but my custom intercooler also bolts into the removable piece making it just as stiff either way always consult your engineer before you start any cutting
cheers wayne
Posted on: 2006/10/12 8:09
82 1200 ute ca18det project still building
You can get a CA18+gearbox in without cutting the front apron if you get the front pulley machined off the balancer!!!
After that it's just a matter of jacking up the BACK of the car and it should just squeeze in in one peice.
Posted on: 2006/10/12 8:33
From SE Melbourne
Yeah Daveman - I think I will try it the 'hard' way first....then if there is trouble resort to a rad support mod.
My friend the panel beater is just getting a little keen to do some cutting I think.
Posted on: 2006/10/12 11:33
Mildman, Datsunless
Mildman, panel beating mates are notorious for cutting things up then not getting around to fix them, the lower d/side rear quarter has been off my sedan for about 2 months now, he has a new one folded up ready to weld on but getting him enthused is near impossible.
Try it the conventional way first. My Ke10 corolla has a removable radiator support top. This is what you want to do isnt it?
Posted on: 2006/10/12 11:52
IPRA Build
From SE Melbourne
WS - yeah that was the thought (clearly influenced by the panel beating mate).
I will give it a crack the non cutting way first - and will be sure to post 6 million photos on the website...
Thanks for the pic too - I hadn't seen too many photos of this approach.
By the way do you regret in on the KE10?
Posted on: 2006/10/12 12:00
Mildman, Datsunless
No worries, this is the way Ke10 and Ke20 corollas are from factory, actually a great little car to work on.
Posted on: 2006/10/12 12:03
IPRA Build
« 1 2 (3) 4 »
