reground cam, setting valve timing
From Bunbury Western Australia
I have a reground cam and am wondering how I should go about setting up the valve timing.
I don't know if I need to set it up with dial gauges and degree wheels or just line it up how the manual says to do it, I mean the locating dowel on the cam would still have the sprocket loacated in the same position so could I just line up the dowel and crank key way like the book basically says?
The cam spec sheet says it has:
at .050 timing
inlet opens 7 BTDC, closes 43 ABDC, duration 229
exhaust opens 45 BBDC, closes 5 ATDC, duration 229
lobe sepperation 109
valve lift .4425 both intake and exhaust
valve lash for both intake and exhaust is .016
Posted on: 2006/10/12 14:07
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
Re: reground cam, setting valve timing
From Christchurch NZ
Chances are you'll need to dial it in proper. When you do, turn the cam sproket around half a turn, and drill a new dowel hole in the end of the cam. Bit rough, but cheaper than buying a flash adjustable sprocket.
Posted on: 2006/10/13 7:33
Forced Induction!
From Adelaide, South Australia
You could also just change how the chain is set.
I'd say you will need to go down the dial deg wheel path.
Posted on: 2006/10/13 8:07
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
bugger, I will look into hiring out a degree wheel, dial gauges and get stuck into it.
I was hoping tyhat since it was a standard cam once upon a time that I could just set it up like it used to be and it would be pretty close, but life was never meant to be easy eh!
Posted on: 2006/10/14 0:18
