Auto tranny locked up
From Melbourne, Australia
hey guys,
was putting the auto motor together for datogal and i've had some problems
basically the whole lot was locked up and wouldn't turn over, too the box off and the motor will turn over, on the input end of the box the inside spline turns by hand but the outside one does not, i'm not sure what is supposed to happen though
on the output side the spline turns except when its in park it is locked up, which seems pretty normal
i did hae trouble getting the tranny on and had to crank it on with the bolts, so have quite possibly stuffed the box doing that
anyone with some auto knowledge can shed some light???
im currently in the search for another auto anyway cause i think i stuffed this one
Posted on: 2006/10/17 3:29
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Auto tranny locked up
From Portland OR. USA
With the auto you have to be carefull to get the torque converter properly engaged in the oil pump before tightening the bellhousing bolts.
IIRC there are 2 splined shafts that go into the torque converter. On the outside of the torque converter there area set of 2 flats that engage the torque converter oil pump.
If the torque converter was not engaged in the oil pump you may have munched the oil pump and possibly jammed the input shaft. Most likely a terminal condition.
Gary
Posted on: 2006/10/17 3:39
From Monroe, wa, usa
i have a jatco from a 210 you can HAVE.....shipping may be a bit on the expensive side though
Posted on: 2006/10/17 5:23
NAPA parts bitch
