Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
wtb 120y sway bar + brackets
dat5_al
Posted on: 2006/10/23 9:29
hey guys want a 120y sway bar with bracket in SA. Does is fit under the sump with a maddat CA conversion.
patts
#2
Re: wtb 120y sway bar + brackets
dattodude
Posted on: 2006/10/23 9:44
unless the engine is hard against the firewall, they won't easily fit with a ca18 installed. It didn't fit on mine, but I didn't use the maddat crossmember.
I ended up getting a custom 23mm one made up, based on the 1200 one, but 1inch bigger step on the front to clear the ca18 sump. I then modified the 120Y bracket to hold the 23mm Eurathane rubbers. the 120y bar is an easy fit with an a-series though.
#3
dat5_al
Posted on: 2006/10/23 9:53
well i guess ill wait till the conversion is fully done and adapt it
#4
possum1200
Posted on: 2006/10/23 9:55
sorry to hijack thread but where did you get your swaybar made up? eg. metal workshop or engineering place etc???
#5
dattodude
Posted on: 2006/10/23 10:27
Allsprings in Liverpool. I gave him a standard 1200 bar, and said make it in 23mm and put an extra 1inch clearance in front bit, It was about $205 including mounting bushes to suit.
#6
tappet
Posted on: 2006/10/26 11:32
if u make up a 30mm spacer brakcet for the d shackles it should just clear the sump with the front at full drop...
but as dattodude said i made my own engine mounts and the motor was as far back as i could get it.. i even had to remove the heater hoses from behind the block.. You can view topic.
