Metal Fabricator/Seat mounting Brackets
From Brisbane
Hi
just wondering if anyone knows a place that makes seat brackets/rail for seat conversion in Brisbane area?
I only need like a 45 degree metal bracket with 5mm thickness
2 sets for driver and passenger side to be welded on to the stock rails.
dont have a welder
Cheers
Posted on: 2006/10/27 9:57
Re: Metal Fabricator/Seat mounting Brackets
if you know what you need and the dimensions any steel fabrication or engineering workshop should be able tohelpyou out at anywhere around $70-90 an hour. or if you know an exhaust shop they'll usually weld anything you want
Posted on: 2006/10/27 10:09
From Brisbane
might try the local exhaust shop cos they normally have small strips of metal for exhaust brackets
Posted on: 2006/10/27 11:47
From Brissy
how far are u from Yatala???
i can help u out tomorrow arvo...
a six pack of xxxx would be on the cards though
Posted on: 2006/10/27 12:10
From Brisbane
Not far
probably 45mins drive
I'm still looking for some metals brackets to suit
probably not this weekend
cheers
Posted on: 2006/10/28 7:30
