« 1 (2) 3 4 »
Re: engine wont rev past 4500rpm
From Bunbury Western Australia
Ok I Thought I would let you know a few more details of todays research and testing
First off the carb has a brand new brass float, the dizzy, leads and plugs are all new, the plugs were gapped to .044" as thats the standard gap for the Bluebird series 2 L series motor, which is what the dizzy came from.
But today I removed the plugs and regapped them down to .035" and the motor will rev like normal, well pretty close
I think it may be a bit lean as the plugs are a light pinky brown colour and power feels a bit sketchy and buzzy at full throttle once the revs start to climb over 5000rpm.
What is the correct colour for the spark plug? I heard that white is too lean, black is too rich but somewhere in between is about right.
I have a fuel pump with three tubes coming out of it, an inlet, an outlet and another tube I am not sure of, it has a tiny hole in the end of it and fuel will come out of it if I leave it unplugged, I am guessing it is a fuel return line, the motor came out of a C20 vanette
Thanks for all the help gang your all helpful legends
Posted on: 2006/11/15 21:42
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
From Adelaide, South Australia
Yeah white is lean or hot.A little black is good.
Posted on: 2006/11/15 21:50
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
I recently helped a mate do this conversion (vanette a15 to a12)... we used the a12 feed line from the pump to the carby. It has no return.
Posted on: 2006/11/16 5:50
From west sydney
If the carby floot had sunk it would be flooding at idle.
Reducing the plug gap helped maybe the coil is starting to breakdown, & is missfireing under hard load, maybe you could beg borrow or steal one just to test it. A series dont have a halmonic balencer they are just a steel pulley, very rare to come loose, you would get some niose or vibration if it did.
Trev
Posted on: 2006/11/16 8:11
nothin revs like a GX
ok update number two
well the missing come back again so I am thinking it must be crook plugs as the coil is brand new and it doesn't get hot, I checked the plugs again and it looks to be running lean still so I removed the top of the carby to change the main jets to 150's and noticed the fuel level in the bowl was about an inch so it isn't flooding from a sunk float.
Then I thought i should check the idle mixture screws and then I got a shock, the screws had vibrated themselves to fully seated position which is why it was idling all over the place!
I will fit a new set of plugs and set lean best idle settings again and see if that has fixed it
This just keeps getting stranger, is there something i can do to stop those idle mixture screws from vibrating out of there settings?
Posted on: 2006/11/16 20:11
Run some fuel injector cleaner or carb cleaner and also check that all your wiring is right for that dizzy. I had a similar problem when I changed to an elec dizzy modded from an e15et. I wasnt running the right type of coil also. Hope it helps.
Posted on: 2006/11/17 0:15
the carb was rebuilt and chemically cleaned before I bought it and before I rejetted it I blew all the fuel passages out and all the jets out with carby cleaner.
The bosche catalogue reccomends the HEC 715 coil for use on the bluebird series 2 and ferrol errol explained to me how to wire the dizzy up correctly.
I am starting to think that the plugs have gone off even though they look ok I think that by running a bit lean for a while and by having the plugs gapped to .044" it has caused the plugs to fail.
I can remember converted saying something similar about that
Posted on: 2006/11/17 6:17
In that case plugs are cheap
Posted on: 2006/11/17 20:36
I have bought a new set of plugs and gapped them to .044", fitted 150 main jets and fitted an O-Ring to the idle mixture screws to stop them from vibrating loose again. I guess all that is left to do is see how it runs now.....fingers crossed
Posted on: 2006/11/18 7:01
AAAARRRRGGGGHHHH this is driving me nuts!
It runs spot on at cruising speeds and around town I can't fault it no hunting missing or anything. But if I give it a boot ful it is almost like a rev limiter cutting in at about 5500-6000rpm and sometimes it will rev right out liie nothing is wrong, What is going on? the plugs look like the mixture is perfect, I don't know what else to change, the fuel filter perhaps?
Posted on: 2006/11/18 16:46
« 1 (2) 3 4 »
