« 1 (2) 3 »
Re: FS: blow through turbo kit
From Canberra
you know you want it Tommy
did I mention the pssssschhhtt!
Posted on: 2006/11/16 19:11
do u know what was done to the carby?
Posted on: 2006/11/17 17:28
From Canberra
unfortunatley no... but it held enough boost to blow the pistons
Posted on: 2006/11/17 17:38
From Adelaide, SA
You can tell if the dizzys locked by twisting the drive gear while holding the rotor button. If its locked, they should both turn together.
If not locked, there should be some give between the 2 shafts via a stiff spring. (this'll only happen in 1 direction though).
Posted on: 2006/11/17 19:51
From Melbourne, Australia
having done the work aswell
its a good price for the amount of pain it will save someone
Posted on: 2006/11/18 6:50
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Rocky Queensland
but the turbo is NOT in working order is it? im contemplating buying this kit. gotta get the ute road registered first tho
did you have it on your car. how come your selling?
Posted on: 2006/11/18 7:16
hi that would be a nuts setup I am considering this for mine only thing i might not have the space to sit that in there.
Posted on: 2006/11/18 7:36
sorry mate. could u explain what the hell that is. doesnt even look like its in the engine bay. is that a marine motor?
Posted on: 2006/11/18 7:44
their u are a thread is up so i dont steal his thread. could u have an estimate at the power this kit is making?
Posted on: 2006/11/18 7:53
From Canberra
by campo on 2006/11/18 17:16:58
Like it says in the ad the turbo needs a new seal between the housings. Its a standard turbo and they arent expensive.
Its not on my car as can be seen in the pics, car is sold.
Posted on: 2006/11/18 8:59
« 1 (2) 3 »
