« 1 2 3 (4) 5 6 7 ... 17 »
Re: SUPERCHARGING A15
From Stray-ya
And if anyone can help me link these damn pics up it would be much appreciated
Posted on: 2006/12/6 10:31
From Toowoomba QLD
1st one
2nd one
3rd one
Posted on: 2006/12/6 10:45
From Toowoomba QLD
I think if you click on the photo in your album so that only it comes up (when it appears with the comments etc, click on the photo again), then get the url from the properties and link that it will be ok.
Cheers Andrew
Posted on: 2006/12/6 10:56
From Stray-ya
still struggling- tried a few times but it seems I will just have to use links.
BTW.... the welding looks pretty bad because it is. If you buy a cheap mig and run it with gasless wire, it will stick two bits of metal together, but don't expect it to be pretty. The welds are sound, but for this kind of stuff I get better, cleaner welds from a stick welder (manual arc). I actually got better results from this welder using stainless (with nitrogen gas) than using the gassless wire on mild steel. Go figure.
Next step-
check the placement
side view
back clearance
Add a pulley
fit the belt..... this one is too big by about 20-40mm
Just need to get the manifolds made up & I should be breaking geaboxes in no time
Posted on: 2006/12/6 11:51
From Darwin NT
1st one
2nd one
3rd one
4th one
and last one
Posted on: 2006/12/6 13:29
current project 4x4 patrol...
From Stray-ya
Awesome dude, can you rig up EFI as well?
Posted on: 2006/12/6 13:41
From Darwin NT
if you want to post a pic in a forum just right click the image you want to post up go to properties highlight the URL then right click it copy the text then go post it up then there will be will be an IMG to the right of the URL button press the IMG button then a window should come up paste the text there then press ok then press ok again
Posted on: 2006/12/6 13:49
From Stray-ya
Yeah, I know I have been trying exactly that procedure
[img]http://datsun1200.com/modules/myalbum/photo.php?lid=11091&full=1[/img]
and lost patience with it
Posted on: 2006/12/6 13:58
From Darwin NT
dodgeman seems to be havin the same sought of problem to Open in new window
Posted on: 2006/12/6 14:00
From Perth
Did you make me a set of brackets while you were at it ?
Posted on: 2006/12/6 17:46
