some short datsun questions
From The garage, NZ
Hey all
just need to know one or two things...
anyone know the width of a h190 diff? i want to use it hopefully in an tube chassis car im making and need to compare widths.
On a different note; what are the standard intake and exhaust valve sizes for an a15 and do they differ from a12-a15?
Hopefully someone know the answers to these q's
Cheers
Chris
Posted on: 2006/12/7 17:27
Re: some short datsun questions
Width of H190 varies, depending on which one you are talking about (truck, various cars, van, etc)
Valve Sizes
Posted on: 2006/12/7 17:31
From Adelaide, SA
Hey - who put together the Wiki? Was it you DD?
Nice!
It's not advertised as much as it should be!
Posted on: 2006/12/7 18:53
From The garage, NZ
where can i find the widths of the h190 diffs? like, all of them ? does anyone know any of them.
thanks dd for the wiki links. good sh*t there.
are there any other wiki-datsun explanations?
Posted on: 2006/12/8 16:02
From Christchurch. NZ
As Far as I know there is 2 different widths, and I have one of each. One is 50mm wider than the other.
Posted on: 2006/12/8 17:31
From bathurst nsw
ill back that up dattodevil the one in the 1500 ute is the wider one by 50mm im not sure what the other diff i have is out of
Posted on: 2006/12/10 20:45
My car gets me from A to B...Just faster ;)
From Burbank, CA
Valves:
intake - 29 - 30mm
exhaust - 35 - 37mm
oddly a GX head would have the smallest of each... But can have the larger size.
don't just worry about the size, the grind if the valve and seat is probably more significant.
Posted on: 2006/12/11 2:58
|||\ 81 KPB310 /|||
