tierod end to suit 200b steering arm
From Geelong, Vic
while i was in the progress of pulling all the useful parts of some of my old datsuns found out that 180b outer tierod ends are the right size to fit in 200b steering arms and also go onto 1200 and stanza tierods
for those who dont know, 200b and 180b steering arms have the balljoint hole offset as to give a slight increase in camber when using bigger datsun struts
heres a pic with 180b one on the right
Posted on: 2006/12/10 13:16
Re: tierod end to suit 200b steering arm
From Springwood NSW, Formerly Tas.
thanks.. that helps me alot..
Posted on: 2006/12/10 16:02
1978 120y Coupe.
From Geelong, Vic
no problem, i know there are a few members that were using 200b steering arms ans had to make up tapered spaces for the tierod end
this should make it alot easyer for them
Posted on: 2006/12/11 8:27
From Taupo New Zealand
which balljoint do you use with 200B steering arms then?
Posted on: 2006/12/11 16:11
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
From Geelong, Vic
stanza or sunny balljoints
need sunny or stanza control arms too, as you do with all the bigger datsun struts
Posted on: 2006/12/12 9:54
