« 1 (2)
Re: A15 Forklift Head and C22 Van Bellhousing query.
From Burbank, CA
something like that.
while trying to hunt down a spec sheet for one, i noticed that there was an A14T forklift engine... which might be found in the nissan powered concrete pumps.
Industrial A15 specs W/ Dyno
what is an H25 engine? there are a bunch of engines we never see for industrial apps
Posted on: 2006/12/11 18:23
|||\ 81 KPB310 /|||
The H-series engine was used in the Datsun 2000 Fairlady Roadster, IIRC. The H25 must therefore be version of the same engine.
See http://en.wikipedia.org/wiki/Nissan_H_engine, and add the information you got on the H25 to the article.
Posted on: 2006/12/11 18:38
From Burbank, CA
yeah i was wondering if the H25 industrial was the same line or something else, since it wasn't used since the early 70's
Everything i see would make me think the forkllift motors are a 9:1 compression round port head. They are intended to spend their lives running under 3600 rpm. Peak HP @ 3600 rpm - 46HP at intermittent duty, 36 continuous. They are very conservative, at 36 HP that engine will run forever.
Posted on: 2006/12/12 1:50
|||\ 81 KPB310 /|||
« 1 (2)
