Re: L18-A14
From Melbourne, Australia
from memory the gx bonnet doesnt bulge underneath, or if it does its not much, ill have to have a look next time im there
Posted on: 2003/2/2 11:42
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: L18-A14
sectioned the hoop and moved it about an inch rearwards
L18_B110 didn't say the crossmember was lowered or even sectioned lower ... it says sectioned to move rearwards, with the mounts welded on lower ... can you clarify if the x-member was also sectioned lower?
The GX bonnet doesn't have much of a bulge, see the Fibreglas GX Bonnet picture.
Posted on: 2003/2/2 12:42
Re: L18-A14
From Brisbane, Australia
the x-member is not lowered. L20B fits under a standard bonnet with no problems. You could do it without sectioning the x-member, and modifying the sump instead.
to answer datto_dave's question, the 120Y diff is stronger. Everything else is the same - ratio, width, and it bolts in (need the 120Y tailshaft).
Posted on: 2003/2/3 0:59
Re: L18-A14
From Kyabram vic, aust,
I have fitted a L20b in to a 1200 and to do it I turned the engine crossmember around so the brackets for the engine mounts pointed back instead of foward. then I recessed the firewall back so I had plenty of room up the front for an intercooler.
I made up engine mounts which got the motor down rather low and just modified a datto 1600 sump to fit, I also put in a 1600 auto trans tunnel and there was heaps of room but it all took stupid amounts of time to get right and the ca18 set up is much simpler, and in the long run cheeper.
Ive got a pic of it some where Ill try ti find it and scan it
P.S these noodles are really nice, I must get some more
Posted on: 2003/2/3 12:22
Re: L18-A14
get "mi goreng" noodles
and drain the water out before you put the flavour in (not too much chilli, if any, its hot stuff)
then and only then you will know what 2min noodles are all about!!!!!!!!!!!!!!!!!!!!!!!
Posted on: 2003/2/4 8:24
1200 Coupe Rallycar
Re: L18-A14
From Fort Worth, Texas, USA
These noodles wouldn't be "bunny" flavored, would they?
Posted on: 2003/2/4 19:12
"There are 10 kinds of people in the world, those who understand binary, and those who don't.
Re: L18-A14
From Sydney
L18_b110
I've only just opened access to everyone to the L18 conversion page. It was blocked cause its no where near finished. It has a few errors and is kinda messy. Just havent had time to fix it all up. Been busy with studies and assignments. In Fact, thats what im supposed to be doing right now, gotta go!!
Scott
Davo
Posted on: 2003/2/7 4:41
« 1 (2)
