« 1 (2) 3 »
Re: 38 dgas weber
From Bunbury Western Australia
I would say try bringing your timing back to 5 degrees and either reduce the size of the air correctors on top of the emulsion tubes down a size or increse the main jets up a size until you are happy with the results.
Once you are happy you can try the full throttle plug test where you hammer it until red line on a issolated piece of road in 2nd gear then immediateley put the car in neautral and switch the engine off, brake to a stop and check the plug colour for lean or rich main fueling conditions
Posted on: 2006/11/24 13:05
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
Re: 38 dgas weber
From Saskatchewan Canada
Blofly,did you test some other combinations in your 38
Posted on: 2006/11/28 19:37
1400 bakkie -sold
1200 GX 4 door -sold
Re: 38 dgas weber
I am pretty happy with the idle / slow speed circuit and I am almost ready to start fiddling with the main fuel circuit to see if I can get more out of it, but a broken engine mount has delayed my testing time this week
will get stuck into it and let you know each detail of the tests soon hopefully
Posted on: 2006/11/29 8:37
Re: 38 dgas weber
I cant seem to sort my idle/slow speed cicuit,it keeps being jerky and struggling to idle at a constant rpm. ANY IDEAS ?
Posted on: 2006/12/21 20:35
1400 bakkie -sold
Re: 38 dgas weber
Have you checked your valves??? Jerky iddle could be due to valves that are not properly adjusted.
What about the distributor and ignition system......
BTW, any pixes of the DGAS Dattos???
Posted on: 2007/1/13 8:33
Re: 38 dgas weber
I toke off the carb yesterday,will be sending it for a overhaul cause there is some wear on the gears and shafts and i am going to change the intake cause i am not happy with the way it was made
Will let you know when its on and running again
Posted on: 2007/1/14 16:23
1400 bakkie -sold
Re: 38 dgas weber
I wish someone could make dual downdraft manifolds. A dual DGAS for a modified motor would be awesome. Even a twin DGEV.
Yes, a twin DCOE is the dream, but for those LHD Dattos and for those Datsun guys that do not have the technique nor the expertise to get involved in relocation of the master cylinder.....or simply for the better breathing ( some DCOE's are so close to the strut towers that I always wonder how good ..or how bad could it get ) two upright DGAS or DGEV's would have plenty of space and non master cylinder issues.
I will look into it...working on Dattos projects is cool.
Posted on: 2007/1/14 19:28
Re: 38 dgas weber
I am sure someone had done this already, i saw a pic on a forum.Dont know if it was this one!?!
Can anyone help here
Posted on: 2007/1/15 17:56
1400 bakkie -sold
Re: 38 dgas weber
From Canada
Dual downdrafts have been done. Can't remember where.. On a 510 I think.
Posted on: 2007/1/15 19:08
Re: 38 dgas weber
I have several "L" series manifolds within reach , so I am going to work on making dual downdraft carburetor manifolds for a Datto. If it works, we can apply the knowledge and experience to our A engines.
I am not an expert in welding ( I welded stuff at my body work ( I think you guys down under call it "beaters") school...but nothing like manifold aluminum....so any info will be appreciated. A dual downdraft is a performance set up, several BMWs and other european vehicles have this Weber kit.
Posted on: 2007/1/17 5:03
« 1 (2) 3 »
