120Y diff ?
From sydney
i just picked up a 1200 sedan off TUFDAT and it had no diff?
i'm just woundering if i put in a 120Y diff in, will everything bolt up?
can anyone help thankx...............
Posted on: 2006/12/22 11:25
Re: 120Y diff ?
From Geelong, Vic
if you get the tailshaft and the leaves from the 120y then yes it will bolt straight in
you need the take the very bottom leaf and the rubbers and stuff that go around the rest of the 120y leaves
this stuff
then bolt it all onto the 1200 leaves, and you will also need the 120y U bolts and bottom plate
Posted on: 2006/12/22 23:32
Re: 120Y diff ?
Do you want a diff, or a whole rear end?
The H150 diff from a 120Y will bolt into the H145 axle housing of the 1200, but a 2mm spacer plate would be desirable along with a second gasket to seal it all up.
You would also need the tailshaft from the 120Y as the drive flange is different on the later diff & the 1200 one will not bolt on.
Posted on: 2006/12/22 23:42
Love your Datsun.
Treat it well.
Re: 120Y diff ?
From sydney
do you think i should just look around for a 1200 ute diff..?
Posted on: 2006/12/23 11:06
Re: 120Y diff ?
From Geelong, Vic
swapping it isnt really that hard, the whole diff assembly that is
you will sooner get a 120y diff and have it working in a 1200 than you will find a ute diff at a reasonable price
Posted on: 2006/12/25 2:12
Re: 120Y diff ?
From sydney
yeah i found one at a good price $150 whole thing...
Posted on: 2006/12/25 23:01
