can someone point me in the right direction
hey all im building up my a15 at the moment im building it to gx spec so mild cam, dbl valve springs twin carbs high comp pistons.
now this is were i need help i need to know where you guys got ur high comp pistons hoping to bring the c/r up to 10:0:1 from 9:0:1 i think thats right. so any help would be much apprectiated oh and if you have any suggestions on pistons from other cars that would be great cheers guys
p.s im keeping my standard bore
Posted on: 2007/1/20 1:29
Re: can someone point me in the right direction
In USA I know J E Pistons in Huntington Beach. I am sure there are excellent places closer to home.
Posted on: 2007/1/20 2:34
From Inner west nsw CAMDEN
Endurotec pistons is wat i used in my a12 so they could probably do a high comp piston too, google search the name i forgot wat complany it was.
Posted on: 2007/1/20 4:59
FAT 120Y SR20de-NOS
What speed are you doing at M kmh???
Bet my bonnet scoop is bigger than YOURS!
Do wheelie bars suit a street car?
i just googled it and it had hypertec (endurotec) pistons do you think hypertec was the brand?
Posted on: 2007/1/20 6:19
B
U
M
P
Posted on: 2007/1/21 5:39
The best and easiest way is to use the Datsun Competition A14 cylinder head. It has the fuel-efficient and power-making "heart-shaped" combustion chambers (closed chamber head). Finding and buying one will probably be less expensive than buying custom forged pistons or re-machining Suburu Justy pistons.
See A-series Cylinder Heads.
Posted on: 2007/1/22 3:06
i have an a15 which has the heart shaped cumbustion chamber and oval ports standard
dd do you know the stock c/r of an a15?
Posted on: 2007/1/22 5:35
From brisbane
then you could get some a14 pistons and get either or the pistons\rods\block shaved (NOT ALL, one or the other)
Posted on: 2007/1/22 6:24
will the stroke being different affect this in any way? and why a14 pistons wouldnt they be the same as a15 pistons?
Posted on: 2007/1/22 7:19
