SEAT QUESTION
From Inner west nsw CAMDEN
will ca18 180sx seats fit into a 120y with little or no mods??
Posted on: 2007/1/22 8:59
FAT 120Y SR20de-NOS
What speed are you doing at M kmh???
Bet my bonnet scoop is bigger than YOURS!
Do wheelie bars suit a street car?
Re: SEAT QUESTION
From Sydney
im trying to put my wrx seats im my 120y coupe(auto body) and to retain the seat rails it wont be an easy job.
Posted on: 2007/1/22 10:03
Re: SEAT QUESTION
i know the amoutn of mods to get aftermarket seats even late model in but im not sure about the 180 ones cause they already have the half half rail i think
Posted on: 2007/1/22 11:15
FAT 120Y SR20de-NOS
Re: SEAT QUESTION
From Tamworth , NSW
rip em off and whack the 1200 rails on em
Posted on: 2007/1/22 11:32
Re: SEAT QUESTION
From Rocky Queensland
i put wrx (imitation) not sure if theyre the same rails. but i had to cut and replace the original rails inside the car. not a hard job. just need dropsaw and some angle iron.
sorry. mine was in a 1200ute. not sure if theyre the same rails
Posted on: 2007/1/22 23:47
Re: SEAT QUESTION
From Toowoomba Q Australia
keep your original rails so that its easy to bolt to the floor. Make a template of the new seat bolt location on a square piece of cardboard or ply . then you can start to determine the mods required .It may also help to just pull out your existing seats and just place the new ones in. This will give you some idea of height &width and see if there is any serious problem like seat belt mount location or maybe your doors wont close(although i doubt that would happen)
Posted on: 2007/1/23 0:33
Re: SEAT QUESTION
From Tamworth, NSW
wow shirley thats some serious lean on that green car in your avey. Might look into a saybar upgrade
sorry to spam
Posted on: 2007/1/23 0:57
Project coupe:
Just drive it
Re: SEAT QUESTION
i have a fixed saas in my 120y for my height im 6'4 lol im asking for someone, but it would be an interesting job to do a seat conversion with rails but mine doesnt move its 1 piece
Posted on: 2007/1/23 8:59
FAT 120Y SR20de-NOS
Re: SEAT QUESTION
From Sydney
The problem with fitting the wrx seats and retaining the wrx rails is not so much getting it bolted in, rather its getting them to sit low enough. even with the seat rails removed it sits bout same mabey even a tad higher than standard. so to do it ill have to cut down the body rails if u know wat i mean. ps this woud be much easier in a manual body as the big auto tunnel adds a few more spanners to the works.
Posted on: 2007/1/23 9:46
Re: SEAT QUESTION
From Perth WA
I have S13 seats in my 1000. The intergrated headrest design ones. All i did to make them fit was bend the front 2 hole 'tabs' down to 90 insted of 45 deg. then drill a hole in the box section the original seats sat on and put bolts through it. For the back i will just be making brakets up with C section and weld that onto the floor and bolt the seats to that...
But this is all useless to you unless 1000 and 120Y floorpans are simmiler... I only used those seats because I got them for free!
Posted on: 2007/1/23 12:50
Chris...
