Parts crossover from B210 to B110
From Seattle ,WA.
Does anyone know if parts such as master cylinders for both the clutch & brakes are the same for a 110 & a 210?
What other kind of parts are interchangable between the two models? Brakes (shoes, calipers, etc..), wiper motor, Alt., starters, you get the idea.
Anybody have the answer?
Thanks, Evan
Posted on: 2007/1/23 2:59
Re: Parts crossover from B210 to B110
From Castro Valley,CA USA
The headlights
The master cyl may bolt in, but it's a different size internally. The clutch master might be the same.
I think brake shoes, drums, fuel filter, clutch slave from a 210 (b310) are the same too.
Not many interchange as identical, however, some parts are used to up grade the B110.
The engine (a14/a15),
trans (5spd),
radiator(some models are bigger),
alternator (larger or int. regulator)
oil pump ?
fuel pump ( needs modification for A12)
210 struts ( more cartridge variety and slightly larger brakes)
210 lower control arms (for the 210 struts or to 280zx struts)
I don't remember what else. This is not THE answer, it's just an answer.
Posted on: 2007/1/23 5:59
From Seattle ,WA.
Thanks, I would never of guessed about the headlight!
How about clutch components?
Thx.
Edp
Posted on: 2007/1/24 1:07
Strangely this has not been a common question but has discussed several times about the B310.
In any case, B210 data is in the wiki. See Wiki - Parts Interchange
Please feel free to add to the article so anyone can easily find it with the wiki search engine. The wiki should be "The Answer" as people keep adding to it. Anyone can add to it.
Posted on: 2007/1/24 1:59
Do 1200/B110 Datto wheels fit B210/120Y's?? Both are 4 bolt pattern, but it could be differnt 4 bolt.
Posted on: 2007/1/24 5:22
yes they are the same i would think all datsun 4 stud wheels would be the same the pcd 114.3 is common for 4 stud pattern wheels so not hard to find decent mags for them
Posted on: 2007/1/24 5:24
Cool ! I am going to score a set of 12 in stock steel wheels....
Posted on: 2007/1/24 5:35
Jaime, the B110 12" wheels won't fit our American B210s which have large brakes.
In Australia (the lucky country) all their B210s came with A12 engines and 12" wheels ... while we were stuck with the gas-hog A14 needed to haul around our heavy park-bench bumpers.
Posted on: 2007/1/24 5:42
From Selah, Washington
What park bench bumpers?
I do have an 81 210/B310 if any one is interested in some parts off of it before it goes to the wreckers.
Posted on: 2007/1/24 6:15
Thanks for the holler! I will verify the fit. I am sure they will not after what you said DGonz..... bummer.....
Bluemax......seems like the park bench bumpers are something of the past for you!
Posted on: 2007/1/24 6:20
