ADVICE AND HELP ON WHERE TO START FIRST or how to start
From Far, far away
ok i am picking my shell of a ute on sunday ( jan 27th) and as u can see from the pitures a lot of work needs to be done.. my hubby says i have to rub back the panels and stuff...and one have any more help on how n what i should be doing first off from what u can see from the pics? i know its hard to tell from pictures n stuff but any help or advice/tips is much appreciated
kirstie!
- i am putting on a normal door here i don't like the shaved look
Posted on: 2007/1/26 7:01
Re: ADVICE AND HELP ON WHERE TO START FIRST or how to start
From SE Melbourne
any way to make the pics a little bigger? Bit hard to see especially the back of the ute
Posted on: 2007/1/26 7:03
Mildman, Datsunless
From Adelaide, South Australia
I'd say get of much of it as you can sand blasted.
also make sure you dont get bored of it other wise it will never get finished.
Posted on: 2007/1/26 7:42
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
From Tamworth , NSW
2 words,
paint stripper.
Posted on: 2007/1/26 7:43
You can get the paint removed by a professional abrasive blaster, but stay away from 'sand' blasting as the sharp angular particles will damage the metal surface. A reputable place will have much better materials available that will not damage the body panels.
My car was 'lime' blasted & it was done as a paint removal exercise only, not for rust removal as there wasn't any.
Posted on: 2007/1/26 7:50
Love your Datsun.
Treat it well.
From Wagga Wagga
i don't much about datsun 1200's but i have reastord 2 old dodges do what the other people said get rid of the paint first then worry about the rest. do you have a engin? because if you don't you sould try going with a bigger one try something new and if it works you will be well known. (trust me) ps.(dont ask what type and how to put it in just measue it and thow it in).
Posted on: 2007/1/26 8:03
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
From melbourne
ahhhh i saw that one on ebay ,welll i could give a bit of advice but if you want to know a few processes you can read my ute rebuild thread here
http://datsun1200.com/modules/newbb/v ... rum=1&post_id=&refresh=Go
Posted on: 2007/1/26 8:42
Before you strip the paint and end up with a bare body sitting there gaining surface rust. Think about sorting out the tray floor, what engine you will use, then fit the engine and make a transmission tunnel, sort your wheels out and mod the front guards at the front if need be.
Then once all this is done, you can then begin to sort out the body for paint prep.
Posted on: 2007/1/26 11:04
From Melbourne, Australia
i'm with phunk, make sure everythings the way you want it first, and you have a all the panels you are going to use
otherwise you're gonna double up on stripping and spraying
get the back sorted and start collecting any missing bits (interior/trim)
basically the more decisions you can make and stick to now the less work you will have
Posted on: 2007/1/26 11:12
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Far, far away
this as big as i can get them
Posted on: 2007/1/27 3:52
