horsepower/kw atw
From Gold Coast
just wondering everyone horsepower/kw power your cars have to what mods&engine .
Posted on: 2007/1/29 4:09
z18-microtech-frontmount-t3/t4
-external gate-screamer pipe-
Re: horsepower/kw atw
From SE Melbourne
the 1/4 thread on the main forum or in the wiki would give you a good indication of rwhp and mods.
http://wiki.datsun1200.com/index.php/1/4_mile_time_log
Posted on: 2007/1/29 4:21
Mildman, Datsunless
From brisbane
My CA18DET with a GTi-R T28 and a chipped ecu running 15 psi pulled 163.3rwkw. I have a 3" exhaust as well.
Matty
Posted on: 2007/1/30 9:58
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From campbelltown (sydney) australia
this is a bit off topic but when u get the ecu chipped what does it actually do? i wanna be able to tuned mine up a bit, i dont know whether its the ecu or the afm or something but my car doesnt idle real well, would chipping it do anything?
Posted on: 2007/1/30 10:15
* caution, sunglasses must be worn to view my ca18det *
From Sydney, Australia
My 1/2 tuned, fullhouse ca18det is currently at 178rwkW @18psi, but I expect 220-250kW@23psi for the final result, will know more in 8 days.
Posted on: 2007/1/30 10:31
From Perth
whimpy NA A15 98.7hp atw
Posted on: 2007/1/30 11:42
From SE Melbourne
Well I have a Ford with over 240rwkw....but as kilowatts mean jack for acceleration I'm much more interested in torque.
Posted on: 2007/1/30 12:09
Mildman, Datsunless
From Brisbane
Matty does your turbo have a .8 comp AR and a .86 rear?, i thought gtir turbos are a t25g
Posted on: 2007/1/30 13:38
From Melbourne,Australia
156kw atw on 15 psi when it last hit the rollers
Posted on: 2007/1/31 4:51
From brisbane
Kegs - The ignition curve and fuel mixtures have been modified on my computer. If the only issue you are experiencing is a rough idle I wouldn't bother changing your ecu until you have exhausted all other possible causes. It could be as simple as a split vacuum line.
Short Coupe - The T25G was standard fitment on the S13 SR20DET motor. My T28 is from a Sunny GTi-R and has a .86 exhaust housing and .60 compressor housing. The S14a and S15 T28s had a .64 exhaust housing giving them better response but less power potential.
Regards Matty
Posted on: 2007/1/31 11:03
