« 1 (2)
Re: New cylinder head A14 Oval.
From bend oregon
The temp sensor is on the other side and the water outlet is in the back of the head
Posted on: 2007/2/5 18:45
From Sydney
ive got a strange looking therostat housing up the back that looks like that, its off a late model a12 ill go get a pic if u want.
Posted on: 2007/2/5 23:34
From brisbane
they are both water, front is a temp sensor , rear is for an elbow so you dont have to run heater water return line under the exaust.
there are two temp senser holes on the front (i know i have one)
Posted on: 2007/2/5 23:53
The front one is actually a temperature 'switch' & it ties in with the vacuum advance cutout system in manual trans models.
When the coolant temperature is below a preset value, this switch is off. This allows a relay to open & prevents the 'top gear detection switch' from cutting out vacuum to the distributor, so the vacuum advance works in all gears.
Above the pre set temperature, this switch closes & the vacuum is denied to the distributor in the intermediate gears. Once top gear is engaged, the gearbox switch kicks in & vacuum becomes available to the distributor in the usual way.
This does not inhibit maximum acceleration performance in the lower gears as quick acceleration demands full throttle operation.
At full throttle there is no vacuum anyway, so the distributor sees only mechanical advance.
If you have a dead stock model with this feature, then don't bother disabling it as no performance improvement will be gained.
The temp 'sensor', for the temp guage, is on the other side of the head.
Posted on: 2007/2/6 2:19
Love your Datsun.
Treat it well.
Curtis, I will appreciate that...would like to see a non US version thermostat housing.
About the sensor... I am not worried about it. But if I could get a non US thermostat housing I would get rid of that bulky thermostat housing US cars have. I can always unbolt that big air valve and plug it, but it would be tidier to have a non US housing.
Posted on: 2007/2/6 4:33
« 1 (2)
