Crank angle on a Series???
From Sydney
Getting bored very fast with my twin webers and just looking at my options, was thinking of going fuel injected and might as well get full use out of the ecu. so i was wondering if anyone has modified a a series crank for a crank angle sensor or know of any links to such info????i know i saw someone did it ages ago but i cant find the post.
Posted on: 2007/3/12 19:11
Re: Crank angle on a Series???
From Bendigo, Victoria, Australia.
why? you dont need one to run ECU. use the distributor to get your timing from.
Posted on: 2007/3/12 19:29
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
From Melbourne, Australia
chase a factory elec dizzy from us
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Sydney
i know i could run the ecu fuel only but i'd like to have it run the timing as well using a waste spark setup, reason for this is easy of tunning, automaticly adjusted for changes in temp alltitude mabey even boost etc...
Posted on: 2007/3/12 19:44
From Adelaide, SA
There's nothing 'bolt on' available as far as a CAS is concerned, but to make one is relatively simple.
A mild steel toothed wheel fitted to your main pulley (custom lasercut - cheaper than you think) and an inductive pickup is easily rigged up.
Have a look around the Megasquirt and Megajolt websites - there's a buttload of info there.
Posted on: 2007/3/12 19:48
From perf
i dont think he was refering to the distributor as being used in the normal sense. i run an ems stinger, which is 3d operation and i dont have the cas on the crank. the distributor is modified to become a cas. some discs with slots and led lights is your starting point.
Posted on: 2007/3/12 20:26
From Sydney
Cheers i have a look, was thinking of getting a toothed wheel from another engine and modifing it to fit. now im not a hundred percent sure on how they work how do they go about destigishing between intake/exhust and compression/ignition strokes??
Posted on: 2007/3/12 20:30
From perth
hey y dont you get a front pully made up and go the haltech way with magnets in the pully and sensor mounted on motor (hall effect sensor) you will be able to run full sequential injection and ignition with it and it just so happens i have a complete set up for sale....pm me for extra details...
Posted on: 2007/3/12 21:23
From Tracy ,Ca
here is a pic of my set up[img]http://datsun1200.com/modules/myalbum/photo.php?lid=9664[/img]
Posted on: 2007/3/13 0:15
From Sydney
Arrrhhh bobs1200 thats wat i was after. u must tell me more im very intrested how it works and how u went about making it. cheers
Posted on: 2007/3/13 4:34
