Another 1200 window question...
Ok so I got all the bits off the door and found the track the bottom of the window sits in at the bottom of the door...put it back where it had came from with a gentle tappity tap...problem is...after putting all the trim back on and a few winds up and down later...It fell off again! Arrg now I gotta do it all again.
Does anyone known if these tracks can be glued into place (glue the rubber to the track and the bottom of window itself) to provide enough purchase to pull the window down? Or is it just supposed to be a damn good pressure fit?
Methinks the fact that there are nice tight new seals on the window runners are contributing to the problem.I just dont know if putting glue onto your window might make for more problems later.
what would you do?...glue?(if so what kind?)crimp the track a little tighter?...both?
Posted on: 2007/3/18 0:47
Re: Another 1200 window question...
crimp it a liilte bit first and try then maybe a spot of glue about 5mm from each end... dont go crazy on glue first... incase it doesnt work out.
Posted on: 2007/3/18 1:38
