Re: Dead 1200
Quite a regular
From Toowoomba
blofly wrote:
rings wouldn't just "GO" like that they slowly wear out over a long time
Thats what I was thinkin!
Posted on: 2007/3/19 3:07
If you can't beat 'em,
Arrange to have 'em beaten!
Re: Dead 1200
From Toowoomba QLD
Put a wire direct from the battery to the coil and see if it will run whilst "hotwired"
EDIT: you didn't say that it even tried to fire whilst cranking so this may achieve nothing.
Posted on: 2007/3/19 3:21
Re: Dead 1200
From Stone Age somewhere in U.S.A.
if you have fuel and you have spark, try adjusting the valves. more often than not, as the engine runs the valve clearance gets tighter, eventually causing the valves to actually stay partially open, this would explain the backfire and rough running.
because the engine is cold, set the adjustment at 0.012 in, until it is warmed up and then readjust them to 0.014 in. when hot.
Posted on: 2007/3/19 3:56
Re: Dead 1200
From toowoomba q australia
if when you pour fuel down carby it runs (but poorly), spark should be close enough to run. are you getting fuel out of the feed line between fuel pump and carb (maybe krook new pump - happened to me) or try blowing back into the tank from the feed side of the pump it may just be a blocked pickup in the tank. give it a try.
Posted on: 2007/3/20 7:51
Re: Dead 1200
From Melbourne, Victoria
Rofl it seams everyone has a different idea
ill chuck in my 2 cents
exact same thing happend to me recently under similar circumstances.
turned out to be my exhaust was blocked and had to replace the muffler as the motor couldnt flow and let the exhaust fumes out
perhaps try putting your hand over the exhaust pipe and have someone turn the engine over. If you cant feel any thing coming out the exhaust then its blocked and wont start or run (like the old banana in the exhaust pipe trick)
good luck
Posted on: 2007/3/20 8:37
Re: Dead 1200
From SE Melbourne
There is a good step by step guide here:
http://wiki.datsun1200.com/index.php/Engine_Troubleshooting_Overview
Sounds like ignition timing or valve clearances, but by working through it step by step you can gradually eliminate each possible cause till you find the one that is the problem.
I think ignition releated causes are the most common for car wont start, or car runs like a bag of #### issues...
Posted on: 2007/3/20 18:12
Mildman, Datsunless
« 1 2 3 (4)
