« 1 2 3 (4)
Re: engine wont rev past 4500rpm
From Saskatchewan Canada
Try running a wire directly from the batt. to coil + ,maybe a fault wire and try changing coils as well.
You can always put the standard stuff back,if all is well then you know theres no fuel problem
GOOD LUCK!!!
Posted on: 2007/3/22 15:21
1400 bakkie -sold
1200 GX 4 door -sold
From Bunbury Western Australia
just set timing to 14degrees, a noticeable increase in revs from 4000rpm up to 5800rpm getting there slowly!
Posted on: 2007/3/24 5:14
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
From Sydney , NSW
Are you running the stock tacho??
They (and most old / cheap tachos) can be a rev limiter when they s**t themselves. Bypass your tacho and try again - worth the effort to find out!!
Cheers
Posted on: 2007/3/25 2:58
All torque, no traction
A division of "My mate's ....." engineering
running a cheapish tacho, $130 with a shift light, I will disconnect it and see how it revs, well I will guess how it revs by the sound of the engine
Posted on: 2007/3/25 3:01
« 1 2 3 (4)
