Extractors for Datsun
From tasmania
I have a Datsun 1000 with a A14 sunny motor. Can anyone tell me where to get a set of extractors for it??
Posted on: 2007/4/4 21:14
Re: Extractors for Datsun
your local exhast shop should be able to help you out.
Posted on: 2007/4/4 21:25
From tasmania
yer thanks for you reply no one I talk to in tassie can come up with a set to fit the 1000 only a1400 into 120 y
Posted on: 2007/4/4 21:36
They will fit the motor, you just need to get them cut and welded shorter.
A good exhast shop should do this for you.
i have had it done before.
Posted on: 2007/4/4 21:48
From tasmania
so the style are 4 2 into 1 type are they because I have tryed the 4 into 1 type they wont even go over the engine mounts they are the tuned length type
Posted on: 2007/4/4 21:57
now i remember about that. they are a different type, they bend around weird at the top near the head. not the tuned length ones.
Posted on: 2007/4/4 22:04
From Perth WA
I had to 'modify' my engine mount with a angle grinder to make my 4-1 Genie extracters fit. They just about hit the floor too! I spose you could make any extracters work.
Posted on: 2007/4/4 22:06
Chris...
From tasmania
did you buy your extractors or were they made for you
Posted on: 2007/4/4 22:22
From Sunny Coast, QLD
The guy I bought my car off said he asked about getting some original extactors (an exhaust manifold or whatever theyre called) but it was cheaper to get some aftermarket extractors. I think he said around $300. I dont know who he went thru tho.
Posted on: 2007/4/4 23:01
From Tasmania
Baldy check your PM's you have a message.
would you be interested in a set of 4-2-1 extractors??
Posted on: 2007/4/5 8:50
Proud member of " The Tasmanian Datsun Owners Group"
