1200 ute dying??
Quite a regular
From sunshine coast QLD
Hoping someone can help me, my 81 1200 ute sometimes when accelerating won't accelerate, like engine is choking?? have changed points, coil, rotor arm, air cleaner and have had carbie rebuilt. Any help much appreciated.
Posted on: 2007/4/14 4:43
Re: 1200 ute dying??
From south australia
maby its your fuel pump
Posted on: 2007/4/14 4:52
Quite a regular
i thought it might be the pump, but it seems to be pumping
Posted on: 2007/4/14 4:58
try spark plugs dizzy cap or leads and doble check you have points gap right
Posted on: 2007/4/14 5:13
Quite a regular
points gap has been triple checked. Leads, plugs and cap are all near new
Posted on: 2007/4/14 5:28
Did you change the fuel filter?
Posted on: 2007/4/14 5:31
Love your Datsun.
Treat it well.
Quite a regular
yes, that was one of the first things i changed when this problem came up
Posted on: 2007/4/14 5:32
Quite a regular
anyone had this problem before???
Posted on: 2007/4/14 11:14
From Ipswich, QLD
i had a similar problem with a mazda ute, i took off the petrol tak nd cleaned all the lines and the tank itself, i had about half a kilo of #### stuck in various places in the lines, and under acceleratino fuel would be choked by the muck stuck in the lines. Maybe it's time to clean out your tank?
Posted on: 2007/4/14 12:14
Quite a regular
sounds like a possability. was your problem intermittent aswell?
Posted on: 2007/4/14 13:09
