engine specs
does any know the engine weight, torque, horsepower for a 1200 and 1400 motor need details for rego thanks
Posted on: 2007/4/15 14:33
Re: engine specs
From Adelaide
A12: -
68Bhp @ 6,000RPM
9.7kg/m @ 3,600RPM
Posted on: 2007/4/15 14:51
Nissanman - just trying to help...
Re: engine specs
From Coondle, WA Australia
its all in the specs section on this web page.
in the column to the left is the tech section. its in there...
Posted on: 2007/4/15 17:35
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Re: engine specs
A14: 65 HP
A12: 68-69 HP
See encycloped - Engine Weights
A12 87 kg 192 lbs
A14 93 kg 205 lbs
As you can see, there is no reason to use an A14, unless you can get a high HP (85 HP) version.
Posted on: 2007/4/16 2:26
Re: engine specs
From sydney, northen beaches!
that doeesnt make sense, how can a A12 be just as fast as a A14. And anyone have specs for a A15
Posted on: 2007/4/16 4:45
Re: engine specs
From SE Melbourne
Specifications (from the tech section)
Datsun A12 Engine
Bore: 73mm
Stroke: 70mm
Conrod: 121.5mm
Block Hieght: 189.1mm
Displacement: 1172cc
Power: 69hp
Datsun A14 Engine
Bore: 76mm
Stroke: 77mm
Conrod: 133mm
Block Hieght: 204.1mm
Displacement: 1397cc
Power: approx 78hp
Datsun A15 Engine
Bore: 76mm
Stroke: 82mm
Conrod: 133mm
Block Height: 204.1
Displacement: 1488cc
Power: approx 81hp
Posted on: 2007/4/16 5:43
Mildman, Datsunless
