« 1 2 (3) 4 »
Re: a15 into 1000 sedan
From Coondle, WA Australia
I just spoke to my brother about superchargers, and he said that you can set them up so that they work similar to a turbo, in that at idle, they can recycle the boost (ie none into motor) and then boost up a bit later, and this can be set at whatever, like a turbo. Kida defeats the purpose of a blower, but its more info. I need to find a good turbo shop to talk this over with...
One more question
The original dash was butchered by the preious owner to fit in a single din stereo. Thats fine, buts its really nasty. I was planning on taking it to a stereo shop and get them to neaten it up, but is it possible to fit a DIN type stereo unit from a more modern car into the dash so that the head unit can go in and out and be stable like a new car??
Has any one done this??
Posted on: 2007/4/20 6:19
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Freo
I've cut a DIN size stereo into a 1000, I didn't have any dramas,
Posted on: 2007/4/20 7:23
From Perth
I have a stereo needs fitting Mike
How about you come help me do mine
Posted on: 2007/4/20 7:56
Perhaps I didnt make it clear what I was meaning, and now that I read my own post again, its not very clear.
It already has a very nast y hole cut, and a single din fits, and has worked in the past.
I want to make it like a more modern car, where all you do, is attach the factory brackets to the head unit, slide in, and then screw the brackets to the supporting box in the dash.
I was thinking about a unit from a corrolla (88ish). I had one for a first car, and i think it should be easy to pull out of the corrolla and mount into the dash.
I expect it to mean some welding to the dash from behind. Just want to know if people just use the can that come with most head units and just have em hanging on, or what?
hope thats clearer.
dattoman_1000, I can help you out with the electrical stuff as a part trade for the disk brake kit....
I would have thought that you would be fine with that stuff, or are you just lookng to be lazy...
Posted on: 2007/4/20 21:25
From Perth
Hahaha
I am
1. Lazy
2. Allergic to electrical work
When I do electricals I seem to see alot of blue smoke
I need to do a few things before I need to fit a stereo to the car though
Posted on: 2007/4/21 8:33
From Freo
who needs a stereo Neil when you can tune to DCOE.. ha ha
Posted on: 2007/4/21 8:56
From Perth WA
Nah Neil can only tune to "fcuked out A12 carb"
...(me too)
Thought about a coupe dash? I have one in my wags, ill show ya when you come down on Sunday! Looks alot more modern and betterer!
Posted on: 2007/4/21 9:56
Chris...
From Freo
what happens when he slides in the race motor.. rollers, efi..
Posted on: 2007/4/21 10:02
From Perth
I have the carb off the red 1000 that went to the tip
I'll rebuild it and bung it on the current A15
The throttle shaft is rooted (or the body where it runs thru) on the current carb so its running rough and drinking fuel
Racecar motor will be coming out during the week so the car can be shipped to the new owner (hopefully)
And yes it will be converted to EFI and I'll be selling off the twin DCOE's on manifold
Still wouldn't mind a better radio than whats in it now
Posted on: 2007/4/21 12:16
righto then dattoman 1k
Now that I know what the story is, intriniscly lazy.... hmmm
I guess that when you are talking about a 1,5l 4 pot screamer, then the extra coupla litres of fuel isnt really big issue. People call me mad for using premium fuel in the datto, but for the extra $2 or there abouts it cant be bad for the car, higher octane and all.
Ill call about 11ish to see where you are. Its apitty that you cant see the datto now. the timing cover is somewhat dead. Ill post a photo soon to show.
cheers folks
Posted on: 2007/4/21 22:05
« 1 2 (3) 4 »
