A12/13/14/15 Race Parts, 1200 Window rubber in USA
From St. Louis, MO USA
A12 Race cylinder head with comp valves, aluminum retainers, comp springs $200.
(4) A12 +0.040" Cosworth dome race pistons, used, no pins (19mm pins) $25 each. (Will work wth the A12A rods and pins.) A12A rods and pins $10 each.
(8) A14 Flat top race pistons on rods, used, good condition $25 each.
Crank pulleys, lightweight single groove $45 each.
NEW OE rear coupe window rubber $80.
Very Good used (barely) front coupe winshield rubber $60.
Peter Zekert 314 291-8441 or cell 314 724-7098 peterzekert@juno.com
Posted on: 2003/2/23 20:10
Re: A12/13/14/15 Race Parts, 1200 Window rubber in USA
From Perth
i'm interested in the A14 race pistons
please advise
bore diam
comp height
forged ?
any pics ??
Posted on: 2003/2/24 11:36
From Perth
well ?
Posted on: 2003/3/3 4:58
Write to the seller at his e-mail address.
Posted on: 2003/3/3 5:32
From Perth
did
hence the "well?"
Posted on: 2003/3/3 13:38
Re: A12/13/14/15 Race PISTONS
I have a set of 4 used Cosworth A12 or A13 race pistons that measure 2.091 - 2.902 inches in diameter. They are in decent used condition, usable. for $100 USD. (New cosworths are $600 USD a set here.) These have the valve reliefs and are wedge shaped dome pistons. They have the large 19mm piston pin. Peter at PeterZekert@Juno.com in the center of the USA.
Posted on: 2003/3/3 20:04
From Perth
was hoping to haggle on the A14 ones.......oh well
Posted on: 2003/3/4 13:39
