« 1 2 3 4 (5)
Re: Australian Race Track Times
From brisbane
Hi Harry
I bled the brakes a couple of nights before the meet as I always do. The pedal was firm at that stage but after 2 laps it was significantly softer and has since stayed that way. Any ideas?
I still have a fair bit of the Motul left but I might try the Penrite next time. What times were doing round QR in the GTR?
Matty
Posted on: 2007/4/20 13:04
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
L18_B110 wrote:
fair enough Dodgeman, I guess I'll just have to come down there again! Hopefully with a Datto to run against him.
I'd look forward to that as it's about time someone else got a look-in at the winners flag. I had been holding out to see if the Carpenter brothers could make a contest of it, but so far the mighty KB10 hasn't been able to make it to the track for a variety of reasons.
It would be a real contest if the three of you could compete together, but if Chris' coupe looks like it's not doing so good it might spur the 'secret weapon' along.
I told you when you deserted the small Datsun camp by selling your 1200 coupe that you'd be back.
Posted on: 2007/4/20 14:32
Love your Datsun.
Treat it well.
From Brisbane, Australia
Matty, sounds like the fluid has gone off, or RBF isn't all its cracked up to be. try a total flush of the system. these 600deg fluids don't last very long before they've absorbed moisture and need flushing.
GTR did 61.5 on the sprint track on cheapo Federal road tyres. Since then I've added adjustable upper arms on the front for more camber, some offset bushes in the rear upper arms for less camber and done a proper wheel alignment so it should be a touch quicker now.
Posted on: 2007/4/21 2:05
From brisbane
Thanks Harry
I bleed the brakes before each sprint but I haven't completely flushed the system for ages so I will give that a go when I fit the new master cylinder.
That's a pretty solid time on road rubber. It will be interesting to see what difference the suspension tweaks make. When do you think you will head out again?
Cheers Matty
Posted on: 2007/4/21 22:01
From Adelaide. SA
I just got back from Collingrove Hillclimb tonight with a PB under my belt!! I did a 40.88 which is an average time for the class i was in (road reg over 3000cc). The track was slippery and on old road tyres, i was busy behind the wheel to say the least.
Cheers. Adam
Posted on: 2007/5/27 9:14
It's not for the money and its not for the applause!
"Live life, follow your dreams",
Peter Brock
From SE Melbourne
by gx1200 on 2007/5/27 19:14:45
In what car gx1200?
Posted on: 2007/6/1 2:35
Mildman, Datsunless
From Adelaide. SA
yeah mate. the green gx two door!
Posted on: 2007/6/1 2:45
Peter Brock
« 1 2 3 4 (5)
