Plug readings
From adelaide
I pulled out my plugs yesterday and no 1 was black around the outside but tan coloured in the middle, ive never seen a plug look like this before any ideas, i no i have poor spark. the other plugs were all black as. ill try get a photo too
Posted on: 2007/5/27 21:23
1200 restoration project moving slower than it actually is
Re: Plug readings
From Flinders View, QLD
Excessive black plugs mean rich mixture and or burning oil
Have you checked that all the plugs have matching part numbers, might have 1 plug with a different heat range. What engine are you running, if its injected, number 1 injector may be blocked slightly. May also have a pin hole coolent leak in number 1 as well. Also check the OHM (resistance) readings on your plug leads (if you have leads) and compare results between the 4.
Keep un informed on what goes on
...edit... just read your signature block, turbo l20 engine. that rules out faulty injector, unless its got some funky injection setup on it. Could also just be a fauly plug, you know, just one of those things
Posted on: 2007/5/28 0:37
Just trying to put the bloody puzzel back together
Re: Plug readings
From adelaide
yea it has injection, maybe an injector is slightly blocked there second hand unchecked, i just find it wierd that its black as around the outside yet almost white in the middle. I will definatellly check my leads. Plugs are new ngk for et turbo, and its a fresh motor so shouldnt have any coolant leaking, scary thought!
Posted on: 2007/5/28 9:08
Re: Plug readings
From Adelaide, Australia
Is it sooty black or shiney, oily?
Posted on: 2007/5/28 9:11
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: Plug readings
If you have the time and money get the injectors checked. Make sure you get the results from the injector service to see if there was a problem with number 1.
I know you said that the plugs are NEW but do they actually have the same part number stamped on each of em. Could have been a mix up at the shop or factory.
Could also by wiring to that injector
Posted on: 2007/5/28 22:17
Re: Plug readings
From adelaide
yea outside is very sooty black looks like the rest of the plugs except the middle. I will check the numbers i never thought of that I have to spare injectors im just gonna swap one over as i dont have long to get everything ready for the shop, cheers for the advice
Posted on: 2007/5/29 7:55
