(1) 2 3 4 5 »
double valve springs???
From Perth
Hey Guys,
I am doing up an a series, I have a nice head and cam, but I dont want me valves to bounce. I need some advice on which double valve springs to use on me little 1500.
Cheers
Posted on: 2007/6/3 4:14
Re: double valve springs???
From Freo
8k rpm or 10k rpm..
Posted on: 2007/6/3 4:48
From Perth
is there a special grind of cam i need for 10000rpm springs. if so what do i need. i have a ground cam, i think is good for 10k rpm. how do i identify it?? there is numbers stamped into it but i dont understand them
Posted on: 2007/6/6 11:22
At 10,000 rpm most pasenger car engines have a lot in common with hand grenades, ..... after the pin is pulled.
Posted on: 2007/6/6 11:47
Love your Datsun.
Treat it well.
From South Africa, Bloemfontein
Stock standard Nissan/Datsun double valve springs will do for 7000 to 8000rpm.
Why do you want to rev to 10 000rpm?
It is useless for a street car.
Posted on: 2007/6/6 12:48
1977 Datsun 1200GX
From Perth
7500 is enough for a tuned A15
Thats what I limit myself too and I don't have too much trouble having fun with it
I use Holden 6 cyl double springs myself
But thats to suit my cut down L series valves , lash caps and 1.65 roller rockers
I run pretty hefty seat pressures and tension which may limit my rev-ability but I don't want to rev it any harder than that anyway
100hp ATW is enough for now anyway
More to come with turbo but no more revs
Posted on: 2007/6/6 13:16
From Vic Bendigo
with a desent set of roler5 rockers and double valve springs would it rev past 10 000 with a decent cam and exhaust? and still make power?
Posted on: 2007/6/6 23:46
From Freo
And a killer crank, light flywheel,
light lifters/pushrods, good timing gear,
Posted on: 2007/6/7 0:27
From sydney
by datsun_guy on 2007/6/7 9:46:25
In a word No.
Posted on: 2007/6/7 2:00
From Vic Bendigo
whats a good way of getting the motor to rev harder after webers and extracters? beside valve springs and roller rockers. would blue printing do anything to the performance?
Posted on: 2007/6/9 10:29
(1) 2 3 4 5 »
