a15 gains
From gold coast
hey i own a dato 1200 ute built by trp...its got a 5speed race box,full shaved body, worked a15 which is board with webbers,exsuast system,custom diff plus heaps more......a HEAP of money spent on this ute and i just need info on mods i ken do to the motor eg turbo?....
Posted on: 2007/6/12 23:02
Re: a15 gains
From Penrith, Sydney, NSW
<------------------- The search button and tech section is over there Doyle. Learn to be friends with it!!!
Posted on: 2007/6/12 23:28
"If the doors of perception were cleansed, every thing would appear to man as it is......infinite"
Re: a15 gains
From SE Melbourne
I woiuld approach turbocharging with a little bit of caution - if the engine has been that heavily work it probably has a very high compression ratio - which will make it difficult to turbocharge.
You might be better off fitting a modern twin cam turbo motor if the worked A15 isn't fast enough for you. Like a CA18 or SR20....
Depends really what you are after - it this a race car, drag car, show car, street car....and why do you want it to go faster - is there a goal or target in mind?
Posted on: 2007/6/13 0:31
Mildman, Datsunless
Re: a15 gains
From Geelong, Vic
more importantly where are the pics of this ute?
Posted on: 2007/6/13 1:30
Re: a15 gains
From gold coast
yea i considered the ca18 conversion but the amount of work i would assume is high.......but then again its ben retunneled for the new box so maybe not...wot bout fuel injection or sumthing along those lines
Posted on: 2007/6/13 1:35
Re: a15 gains
From gold coast
ill take sum today.....i only got the ute from syd 3 weeks ago
Posted on: 2007/6/13 1:37
Re: a15 gains
From Geelong, Vic
if its already got webers that are in good tune, making up fuel injection for it and keeping it NA wont give you much of a power boost
Posted on: 2007/6/13 1:39
Re: a15 gains
From gold coast
Yea well they r 32/36 webbs.....4 into 1 extractors...lightend flywheel...2.5inch system....k&n air.... boarded etc etc but i want more boogy
Posted on: 2007/6/13 1:45
Re: a15 gains
Doyle, are you revving it high enough? With those parts, if done right it should be running sweet at over 4,000 rpm. Rev her up to at least 6,000 and keep her revved high for maximum performance
Posted on: 2007/6/13 2:13
Re: a15 gains
From SE Melbourne
Have you had the ute on a dyno to see the sort of torque curve you have at the moment?
Also knowing the compression ratio would be good.
Posted on: 2007/6/13 2:27
Mildman, Datsunless
