a15 79mm boring
From perth
Hey all just finding who has used 79mm pistons in there motors thanks...
Posted on: 2007/6/24 14:19
Re: a15 79mm boring
From perth
any one heard of any problems boring out this far?
Thanks
Posted on: 2007/6/26 6:04
Re: a15 79mm boring
From Stray-ya
You wouldn't have much meat left between 1&2 and 3&4- you sure it would be worth the extra cubes?
how about 78mm RB20? do they have the right comp height?
Posted on: 2007/6/26 6:13
Utes and Roots
Re: a15 79mm boring
From perth
Already got the pistons from japan and its only a motor ay.....if it stuffes up oput some sleves into it and start again...
Posted on: 2007/6/26 6:27
Re: a15 79mm boring
From Christchurch NZ
Before getting a block bored that close to the limit, I would strongly advise getting the bore walls sonic tested to ensure there is enough meat. Due to core shift when casting not every block can handle the jandle when overboring to the max.
Posted on: 2007/6/26 7:00
Forced Induction!
Re: a15 79mm boring
What pistons did you get?
Posted on: 2007/6/26 7:01
Forced Induction!
