A15???
Quite a regular
From wellington, new zealand
hey y'all!
thanx 2 all who helped with the z18 q?, in the same place as th z18 donor is an '87 nissan vanette C20, its a 1.5, wuld i b right in assuming it culd b a A15 engine? or culd it be sumthing else? if it is "A" series it wuld b piss easy 2 mod and fit 2 a 1200, and i think it mite b 5spd too!
Posted on: 2003/3/18 23:01
UFO Unidentifiable Falling Object
me soo sick, head hurts
Re: A15???
From Warwick, QLD
mate fitting an A15 is piss easy, check out 1200rallycar's photoalbum, he's posted a pic of an adapter plate, it looks dead simple to make. I was lucky and already had an adapter plate for my A15 and 5 speeds are easy too, just bolt it up an d then hold up it up with a jack or something and draw up an adapter plate to hold it all up, then take that to a steel fabricator place and they'll knock one up for ya in no time. Well thats alll I did to fit my 5sp.
cheers
Damo
Posted on: 2003/3/19 3:01
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Re: A15???
Quite a regular
yea i already printed out th teplate for th bracket, in regards to the diff in the van, wuld i be beta to fit tht as wel? also, shall i just rip all i can from the van? im guessing tht th springs etc wuld all be a wee bit heavier? im looking for easy adaptibility, th mrs doesnt want car bodies on the property, unfortunatly, so i hav 2 get in, rip out, then dump. has any body got any idea wot th van motor is? as it is, im trespassing on sum old dudes property to look at th wrecks, but are COMPLETE!
Posted on: 2003/3/19 4:21
Re: A15???
From Melbourne, Australia
yo dont want a 5-speed there crap, send it to me and ill dispose of it for ya
i dont know bout the springs but i doubt it, definately not the leafs if thats what your reffering to they are too long
if the diff is a h190, i think it might be, it will be 90mm wider than a stock, therefore you will need fwd offset rims to fit tyres under guards
someone confirm diff model???
Posted on: 2003/3/19 12:49
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: A15???
From sydney australia
okay,to tell if it's an a12 or an a15,check the emissions sticker on the floor under the passenger seat,it should say either a12s or a15s.to check the diff,count the bolts holding the housing to the centre.if it's got 8,it's a h165,& the motor will be a a12.if,however,it's got 10,it's a h190 & the motor should be an a15.
Posted on: 2003/3/20 9:57
Re: A15???
Quite a regular
sweet as, ill get out my torch agen and go commando 2nite, c wot i can find, cheer bol!
Posted on: 2003/3/20 22:58
