« 1 (2)
Re: FS:some good stuff
From Port Kennedy, Perth Western Australia
Nice work on the modified bellhousing. I've been down this path recently and used an auto bellhousing too. But I did it a completely different way and used a T50. If you don't mind I'd like to know: Have you run this yet? Does the gearbox input shaft spigot into the flywheel? Does the input shaft spline line up with the clutch?
I haven't run this yet as the mods are not quite finished. Still needed is a retaining spring for the thrust bearing and a mounting point to take a standard A series clutch cable....easily enough made.
The spigot fits into the back of the crank as per standard but a machined spigot bearing needs to be made to suit the celica input shaft.
Yes, the input spline lines up exactly - there is no other option.
Posted on: 2007/7/8 4:26
A14- SOLD
Tailshaft - SOLD
Posted on: 2007/7/9 13:11
BUMP!
Posted on: 2007/7/18 12:35
Not too shy to talk
You have a PM!
Cheers
PH
Posted on: 2007/7/18 13:15
Thanks PH
I'll get a couple more pics...
Posted on: 2007/7/22 7:21
Stanza discs & struts inc, lowered springs & sunny lower arms -SOLD
Posted on: 2007/7/22 7:40
H165- SOLD
Radiator- SOLD
Posted on: 2007/7/30 6:26
BUMP
Posted on: 2007/8/3 6:05
From perth
gee those rims would look nice of mine..
Posted on: 2007/8/5 17:42
1200 sedan stock sleeper.
Aero Racing
« 1 (2)
