tacho wiring
From Brisbane
just bought a tacho to put in my ute and wanted to confirm wiring.
yellow/red=power
black=earth
black/white(2 off these)=to negative side of coil.
Can some one please confirm this because i dont want to blow the tacho up....
Thanks Jason
Posted on: 2003/3/24 3:54
Re: tacho wiring
Hi n_dorphin, this was discussed recently. Using the search box I found Tacho Connections, which should answer your questions. Or maybe just confuse
Posted on: 2003/3/24 4:00
Re: tacho wiring
From Brisbane
this is confusing. Hope i can do it.
Jason
Posted on: 2003/3/24 4:05
Re: tacho wiring
From Ballarat, Victoria, Australia
yeah i just bought one....but me mate installs that kinda stuff for me...
i watch and learn...its the only way...still workin out where i should mount it....ne suggestions??
Posted on: 2003/3/24 12:28
-1200 4 Door Sedan, 2Pac Aruba Blue, Custom White Interior, OBX Racing Seats, SONY Head Unit, FUSION Speakers, 14" Bathurst Globes, Lowered, Powered By: A15 with Twin 40s,
Re: tacho wiring
From Sydney, Australia
Mate, it's easy. If you know which one goes to 12v, one to earth and the other to the negative side of the coil..then it's easy as...
You can't really blow anything up. Keep away from the high tension lead, if you are wiring up while the engine is running.
Chris.
Posted on: 2003/3/24 12:57
Re: tacho wiring
From Brisbane
ok tried all the ideas, One made wires smoke (+ coil and ign) and the other (using the neg of coil and dizzy) wouldnt start.
Help please
Posted on: 2003/3/25 1:39
Re: tacho wiring
n_dorphin, it makes a huge difference ... is yours a factory 1200 tacho, or is it an aftermarket unit?
If it's a factory unit, go to the other discussion and click the link for the wiring diagram.
Posted on: 2003/3/25 6:34
