« 1 2 (3)
Re: question about oil blockage. any ideas would be a great help.
From Adelaide, Australia
What exactly is the story with this engine? Did you blow a head gasket, and changed heads at the same time? Thats obviously not the head that was on it, coz you said it didn't have a hole.
We run it without the cover on, and not a drop of oil was to be seen. Is it the A-series push-rods that have the hole for the oil to travel up? cant remember.
Pretty sure oil travels up past the T-bolt, coz it's skinnier, and up into the rocker assembly....
Or straight from the block up into the head via that little hole your gonna drill....
been a while since i worked on A-series. Have you got the head off? I can pop round have a look if you like...on the weekend
Posted on: 2007/7/17 14:31
From Adelaide, SA
the third cylinder wasnt doing anything so i had another engine there and decided to change the head. then realised i had put later model head on it. but i have drilled hole and oil is comming through so car is running all good.
Posted on: 2007/7/19 11:17
Again, 'WHAT' head gasket did you use. Yes I know that you got it from Repco, but what was the application that was marked on the packet?
Did it say Datsun A10, or Datsun 1000 & 1200?
If you are using a front distributor engine that is essentially stock, then that is what you need to see on the gasket package.
Posted on: 2007/7/19 11:57
Love your Datsun.
Treat it well.
« 1 2 (3)
