« 1 (2)
Re: Starter motor upgrade with high comp??
From The garage, NZ
well i called up a mate who races a series/1200's and asked what he uses.
He still uses the 1200 a12 starter motor as its the lightest lol but with a huge earth strap and reconditioned.
I would never have thought it would have the guts to do it but i guess i'll have to pull the starter and make it all shmick
Posted on: 2007/7/24 2:59
hay cheater 5
Posted on: 2007/7/29 15:12
go hard , go quick , see yaaaa
From The garage, NZ
ummm yes ???
Posted on: 2007/7/29 15:18
From Sydney, Australia
Just park it on a hill and clutch start it. Only wimps use a starter motor.
Posted on: 2007/7/29 15:23
the gear reduction are not that dear I paid $45 at the weakin yard it still had the bloody price tag on it
Posted on: 2007/7/29 15:26
I wuold like to see you start one the little turds on the flat dattodude Quote:
Posted on: 2007/7/29 15:30
From adelaide
or set up your starting system so you can crank it with no ignition and once its spinning fast fick ignition on and away it goes
Posted on: 2007/7/29 16:07
1200 restoration project moving slower than it actually is
From Adelaide, SA
That's actually really easy to do using the stock ballast resistor wiring.
Posted on: 2007/7/29 20:27
ant that the truth
Posted on: 2007/7/30 5:44
From The garage, NZ
thanks for the input guys.
Mostly to sycodat though, you've got real insite to the problem
Posted on: 2007/7/30 14:09
« 1 (2)
