4Dr sedan H165 ute diff
From New Zealand
Hi has any one put an 1200 H165 ute diff into an 1200 sedan using disc brakes. I having problems with mine trying to get the shocks mounted with out hitting the capiliers.
Posted on: 2007/8/8 22:40
Re: 4Dr sedan H165 ute diff
From Melbourne, Australia
hmmm
could be a problem....
maybe you could slot in some coupe shocker mounting plates to move the bottom points (of your shockers) in towards the centre of the car
Posted on: 2007/8/8 23:37
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Geelong, Vic
even if you get past the shock problem you will most likely find that the caliper will then hit the inner wheel arch, bit of steel between the shock and the wheel
you may be able to cut it out to clear the caliper depending on where the caliper sits
Posted on: 2007/8/9 0:34
whats gonna hit the inner wheel arch?
Posted on: 2007/8/9 1:24
1200 Coupe Rallycar
From Geelong, Vic
the caliper, see the bit i cut out on my car for the calipers to have plenty of room
there were a few dents there from when i had the r31 calipers
Posted on: 2007/8/9 1:35
i havent had this problem or head of it using bluebird disc over drums
have used a banjo bolt on the brake line to avoid that hitting the chassis rail though
Posted on: 2007/8/9 1:36
1200 Coupe Rallycar
From Adelaide, Australia
I've had my shocks mounted up to coupe lower plates, It didnt line up very well. If I cut the sheet metal that surrounds the shock it would work fine except the shocks are closer together at the bottom instead of the top.
I will still have to do this as im going to use a ute diff I bought recently.
Posted on: 2007/8/9 1:42
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Geelong, Vic
sedan coupe or ute?
dont know what the bluebird calipers are like compared to r31, but im pretty sure that the bluebird discs are offset more making the caliper further in, closer to the car, so i would assume that if they are mounted in the same spot as my calipers that they would be very very close in a sedan
keeping in mind my diff is slightly wider than standard so that would also give my calipers a bit more room, and they still managed to hit
isnt the metal on the other side of the shock a chassis rail?
Posted on: 2007/8/9 1:51
Im sure theres sheet metal hanging down to a certain degree, doesnt Freak have a H165 in his sedan?
Posted on: 2007/8/9 1:58
IPRA Build
From Geelong, Vic
on which side?
there is just sheet metal in the side you can see in my pic, which i have cut some out of
then im pretty sure there is a chassis rail fairly sloce to the other side
yeah freak has a h165 in his sedan.....where are you going with this?
i had a 165 in mine but had sedan mounts on it
Posted on: 2007/8/9 2:08
