Re: stanza track issues
From Melbourne AUS
the width of the 2 lower strut bolts (that bolt to ball joint) is wider on stanza. so they wont bolt to a 1200 ball joint.
Posted on: 2007/8/12 22:36
1973 B110 A12
From Geelong, Vic
but maybe the 120ys use a different balljoint that sits close to the LCA like the 1200 ones
not like there are any other really good solutions coming out of this
Posted on: 2007/8/12 23:09
From Melbourne AUS
i can have a look at the 120y ball joints in my ute tomorrow, and compare to my old standard 1200 ones.
your right tho pigdog
i think the thread topic says it all..
stanza = track issues
anyone wanna buy my old stanza struts! haha
Posted on: 2007/8/12 23:12
1973 B110 A12
From Geelong, Vic
how much do you want for your passengers side struts?
remembering that stanza struts are crap
Posted on: 2007/8/13 16:39
From CAMDEN, NSW
Late model 120Y ball joints will fit stanza lower control arms - but if you use stanza ball joints you will get negative camber.
BJ92 1200/120Y 70-76 41MM centre bolt to bolt.
BJ176 120Y 76-77/SUNNY 51 MM centre bolt to bolt
BJ163 STANZA/SUNNY WAGON 51MM centre to centre.
The last ball joint having a greater distance between the bolts and ball.
Posted on: 2007/8/13 17:54
From Adelaide, Australia
BJ176 also fits B120 utes, pretty sure its not for a sunny B310 at all though.
Ive always used BJ163 on stanza and sunnys.
Posted on: 2007/8/13 18:09
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
« 1 2 (3)
