valve spring question
Quite a regular
From Houston,Texas. USA
Are all the a series engines valve springs the same?
Posted on: 2003/4/2 0:49
Re: valve spring question
From Toowoomba, australia
the valve springs in the a10 and a12 are the same unsure about the a14 and a15 though
valve spring
free length.......................45.7mm
1.7992in
fitted length and load.....38.5mm@30kgs
1.516in@66.1lbs
number of effective coils......4.5
wire diameter...................4.275..
0.1693
coil diameter....................26.224mm
theres a bit of useless info for ya
DAVE
Posted on: 2003/4/2 11:43
why go up and down when you can go round and round
And don't forget the A12GX engine has dual valve springs
Posted on: 2003/4/2 20:23
