What Springs??
From Adelaide
i have recently put in my stanza struts and was wondering which springs i should go with, at the moment i have the stanza originals but its a but 4x4 for my liking just wondering what others have used with the stanza struts. i would like the car reasonably low. any car models and/or part numbers would be greatly appreciated.
White Sedan suggested Gemini TD/TE anyone able to feed more info on these as well?
thanks again
Tom
Posted on: 2007/8/28 13:38
Re: What Springs??
From Geelong, Vic
first off, if you would like the car reasonably low then you will have to look into cutting the strut tube down and fitting shorter inserts so that you not bottoming out all the time
gemini front springs will work, but will need to be cut down to the size you want, oooo cutting springs
corrona front springs, from the double a arm front models, will also work and also need to be cut down to size
if you would like a softer(than the gemin and corrona) but still good handling ride, then 200b rear springs are good.....once again need to be cut
Posted on: 2007/8/29 1:34
Re: What Springs??
From Adelaide
Thanks
any other ideas appreciated :)
Re: What Springs??
If you want the car lowered to the stock (or lower) level, use the B110 springs on the Stanza strut after you lower the spring cup. See A10 Strut Swap
Posted on: 2007/8/29 1:57
Re: What Springs??
From Adelaide
so what would be the best and lowest set up i could go with the stanza struts WITHOUT having to cut the struts themselves?
Thanks again
Tom
Posted on: 2007/9/1 13:13
Re: What Springs??
From Adelaide
Tom, i do a custom spring to suit the Stanza strut, they are 250lb and are a super low spring, I shorten the struts to use them and use a shorter insert tho, or you spring wont be captive in the strut.
Scott
Posted on: 2007/9/1 13:40
Re: What Springs??
From Adelaide
how much $$
Posted on: 2007/9/1 14:10
Re: What Springs??
From Adelaide
$155
Posted on: 2007/9/1 14:20
Re: What Springs??
From Adelaide
if u shorten the tube doesnt that mean the wheel will hit?
that include springs?
where u at?
Posted on: 2007/9/1 14:39
Re: What Springs??
Several club members have reported that using stock ride-height, the Stanza struts only give 2" of travel. If that is true, don't even think of lowering it without cutting the strut housing and using shorter insert like 280ZX. These inserts have the full travel , but are physically shorter.
Why 200-250 lb springs? The stock springs, which give a good smooth front ride, are 90 lb/in. The B210 and B310 springs have almost the same rate but are longer.
Posted on: 2007/9/2 1:51
