(1) 2 3 »
original datsun 1200 wirring loom.....Questions..wirring up
i have wired up lights fuse box switches relays etc.
my questions
what coluor are the 2 wires for the blinker flasher(see threw circle relay)
and where exactlt the wires come from
apparently neer steering colomn.
what colour wires is
starter motor
alternator
wipper motor plug on loom
washer bottle wires x2
and
the colour wires that originaly went to battery
theres not many wires to go and i wanted to wire these up before i start on ecu
any help off any 1
thanks guys
Posted on: 2007/9/6 7:25
Re: original datsun 1200 wirring loom.....Questions..wirring up
can some1 have a look???
or tell me off memory???
Posted on: 2007/9/6 8:59
Ah, someone replied to you the other day. See datsun 1200 ute blinker flasher relay???
Posted on: 2007/9/7 2:12
you said both green
i found 1 green
and 2 blacks in that location.
could u double check the 2 black 1s are tighter then the longer green 1
is this true.
Any ideas on the rest of my questions.
Any1
Posted on: 2007/9/7 8:47
Wiring colors are listed in the Datsun1200.com wiki: http://wiki.datsun1200.com/index.php/Wiring
There is also one wiring diagram there.
Warning: I've seen wiring harnesses that don't exactly match the factory wiring diagram, even for the correct year. It seems they change a few wire colors here and there. But the vast majority of wires match the diagram.
Posted on: 2007/9/7 9:17
From Mandurah, Western Australia
The flasher unit - yes one is green. The other one comes from the loom that is attached to the indicator stalk. It is a wire which is hangging out mine is white.
Posted on: 2007/9/7 12:12
Did the diagram I sent not come out???
wipper motor plug on loom - 5 wires Blue/White trace, Blue/Red Trace, Blue, Yellow, Black. The extension lead which plugs into this that goes to wiper motor is not colour coded.
washer bottle wires x2 - Blue/Red Trace & Blue/Black Trace
the colour wires that originaly went to battery - Dont knot what colour. 2 on pos side. One goes to starter and other feeds to alternator via fuse. think it is White/Red Trace
Posted on: 2007/9/7 12:19
should get me outa trouble 4 now
thanks alot guys
Posted on: 2007/9/8 8:33
on the wiki link
there is a possible mistake,
the by wire=main negative battery
the by wire= starter motor 2 key
by = black with yellow stripe
it says the 210 is white with black stripe and i have this wire aswell
can some 1 help
i need to no
what colour the small wire to starter motor is
what colour the main negative wire is
and exact locations PLEASE.
also what colour washer bottle wires are.
please have a look or help some1 asap
Posted on: 2007/9/9 8:56
From Tamworth , NSW
its pretty hard to get the picture from where im sitting.
the best thing to do would be buy a multimeter and manual for the vehicle and nut it out yourself.
Posted on: 2007/9/9 9:16
(1) 2 3 »
