« 1 (2) 3 »
Re: original datsun 1200 wirring loom.....Questions..wirring up
any1 else???
its pretty simple
just need the colour of the wire that goes to the starter motor(small wire).
colour wire that goes to -side of battery
original colour
1971 1200 ute in australia
Posted on: 2007/9/9 10:11
From Melbourne, Australia
wire to starter is black with yellow tracer
your in melbourne arnt you?
i could lend you or copy the wiring diagram for you
Posted on: 2007/9/9 10:16
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Canberra
its also pretty simple to sit down with a volt meter and play with the switches til you find what does what...
the big black one that bolts to the engine bay...?
Posted on: 2007/9/9 10:18
#### off fagit
u have never posted 1 good bit of info
dont post #### on my posts
Posted on: 2007/9/9 10:21
thought so
but says it also go 2 starter on the wiki thing
that helps as i can actualy conect battery to do some testing now if it works
also
whats the colour of the small wire to starter motor
if u dont no its cool ill buy a battery 2morrow and try find out
not in melbourne
but u can email if u want
the last 1 i got was complicated and wasnt clear at all
if it was u that sent it.
thanks for the help anyway
Posted on: 2007/9/9 10:24
From Canberra
yeah good onya mate, I wish you luck. With an attitude like that you may need it.
Posted on: 2007/9/9 10:31
From Tamworth , NSW
i reckon, how do you expect aid when you go off like that, tyrie has had a hell of a lot more useful inpuit than you mate who just expects everyone to get up and sort out your wiring prob. seriously, get a manual they have a comprehensive wiring diagram in the back. its a bit hard for us to make head or tail of the rats nest wiring you have without actually sitting there in front of it.
take it to an auto elec if you cant figure it out.
Posted on: 2007/9/9 10:44
Well, yes, it would be best Demo if you had bought a $10 manual off eBay. I have purchased many for less than $10 USD shipped, including one for $3.
But anyways we're family...here's the answer:
* what colour the small wire to starter motor is
Answer: Black with yellow stripe. It is in the harness that goes along the right side of the engine.
* what colour the main negative wire is
Answer: Black with yellow stripe. It is the biggest wire on the car. It goes from the battery post to the right-most bolt of the timing cover.
* also what colour washer bottle wires are.
Answer: Kangaroo bag wires are BL and LR and located on far left front corner of engine compartment.
Did the 1973 wiring diagram in the club Album help? Don't be put off by USA vs AU model, they are almost identical. That makes me wonder ...which manuals -- other than the Nissan manual -- have wiring diagrams? My Gregory's does not. Intereurope (published in Britain) has the typical Export diagram, labled USA & Canada...
Posted on: 2007/9/9 17:33
This may help I know it is for a 1600... but the wires in my 1971 1200 are exactly the same:
Posted on: 2007/9/9 23:01
oops wrong diagram... try this one:
The one above is good if you are converting to an internal regulated alt!
Posted on: 2007/9/9 23:07
« 1 (2) 3 »
