Fuel pump with oil leak
From portugal
Hi mates! finaly i have my dat on the road, but i have a small problem. the fuel pump has a small hole on the side thet i realy dont know for what it is, but above 2.500 / 3.000 rpm it leak
Posted on: 2007/9/10 0:11
Re: Fuel pump with oil leak
Do you have the original type pump, with a bolted on cover and body?
The fuel pump has no oil feed, and is not under oil pressure -- it is open to the crankcase. So any oil leak is normally with the gasket.
Is your PCV valve plugged? That can cause excessive pressure inside the crankcase and it will come out somewhere.
Posted on: 2007/9/10 1:00
From Brisbane, Australia
this is very common on L series with the standard fuel pump. makes a good old mess. you need to re-kit the pump or get a replacement. personally, I'd buy a cheap electric pump and blank off the block where the mechanical fuel pump was.
Posted on: 2007/9/10 1:44
From portugal
hi mates thank
Posted on: 2007/9/10 17:22
I don't know how much they would cost in Portugal, but over here in Aus you can get them for about $60. A replacement standard pump would be a similar amount, or a kit to rebuild the one you've got would be $20-$30.
Posted on: 2007/9/11 0:46
Same here in USA: electric pump is about $50 USD, as is standard pump.
But the standard pump only lasts 15-30 years ...
But with electric fuel pump, you should get a safety shutoff switch, in case of accident it stops the pump so it doesn't keep putting fuel over the road. Buy a low-pressure pump so that you don't need to buy a regulator. Or get one from a Subaru or Honda.
Posted on: 2007/9/11 1:01
From portugal
I was thinkin in thet problem, the pressure. on ebay there are some cheap pumps, but they wourk at 2-4 bar
Posted on: 2007/9/12 0:13
2-4 bars is 14-28 psi. Too much, a carburetor only wants about 3.5 psi. You can use a regulator with them, but then that is extra cost.
Posted on: 2007/9/12 5:07
